Headlight conversion
Originally Posted by Ryan0260
I did the IPF h4 conversion and it is a huge improvement over stock and doesn't cost a fortune
I pulled out before I traded in for my '12 and the plugs are the same but the tab that locks in place is about a 1/16th" short of locking in. So I used electronic wire cutters (eg sharp and thin) to cut a 16th off and worked great.
^^ x2.
However there's better options than the IPFs (which would be one of the last brand I'd look at - right beside Delta's). Look at the Hellas if you don't want to spend the money on Cibies. They're the same price as the IPFs but are A legal, and B a better beam pattern. Rallylights has them and a harness for $200 or so.
I have the Rallylights kit on my JK and the IPF on the girl's JK.
The IPFs seem to have a better high beam pattern, whereas the Hellas have a better low beam pattern. What makes the Susquehanna kit amazing is the wiring harness that comes with it. It makes a world of difference.
I would go for the susquehanna harness with the IPF lens and some Philips Xtreme Power +80% bulbs.
Speaking of the Philips bulbs, I put a set in the stock headlights on my Dad's JK and that was AMAZING. It puts out more light than my girlfriend's IPF lens with the blue bulbs.
Try the philips bulbs in the stock headlights. You won't be disappointed.
