Headlight Issues When Replaced Stock With LED
Old Jul 26, 2023 | 03:01 AM
wrangler_4life's Avatar
Question Headlight Issues When Replaced Stock With LED
I apologize if this thread already exists, but I couldn't find a problem exactly like mine.
I have a Wrangler JK Sport 2011 with standard transmission. I recently replaced my stock 7" headlight with new LED lights. The replacement was easy and came with an adaptor for the new lights.
My current LED light has an extra wire to connect the outer ring directly to the fuse box. This outer ring should be on at all times when the jeep is running.
After I installed the following situation occurs:
  • Condition 1: Starting the jeep with parking brakes engaged. Only the outer ring is one (proper situation)
  • Condition 2: When I release the parking brakes, the low and high beam turns on and keeps on.
  • Condition 3: If I turn the low beam switch on. The high beam turns off and only the low beam stays on. This is ok for driving at night, but during the day, if I turn my lights on, my dashboard dims and I can barely see the radio LCD.
  • Condition 4: The high beam turns on when I turn its switch on. (also proper situation)
In the beginning, I was suspecting low-beam and high-beam inverted wiring. But they work as they suppose to when I turn them on. The only problem is when I turn the jeep on and release the parking brake.
Does anyone see this issue before? any advice to troubleshoot this?
Old Jul 26, 2023 | 04:10 AM
user 729872082's Avatar
Former Member
I have had weird issues when doing this but not like this. I would call the manufacturer? Mine sent me new headlight assemblies but that didn't resolve the problem. They offered a full refund as well. I called Diode Dynamics and they were very helpful with me even though I did not buy my headlights from them! I ended up getting a little module (really just adding resistance) from Diode Dynamics to fix my issues. Good luck!
Old Jul 26, 2023 | 04:45 AM
Just to understand better. Your headlights are not from Diode Dynamics, but they were able to help you out?
I will contact my supplier again (not luck in the first couple of times), then I will try the Diode Dynamics option. Thanks.
Old Jul 27, 2023 | 06:52 AM
Former Member
Yes that is correct! They were very helpful. This is the link to the module but I would talk with them first to see what they say. https://www.diodedynamics.com/dodge-hyperblink-fix-pair.html
Old Jul 27, 2023 | 08:17 AM
Jeff Pillsworth's Avatar
Your Daytime running lights are programmed to your highbeams, this is the default. With a programmer you can disable The DTR or move it to the parking lights or fog lights.
Old Jul 28, 2023 | 05:25 AM
Thanks! I will look into this too.
Old Jul 28, 2023 | 08:43 AM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
My LED install saw my DRL turning the low beams on not high. Otherwise people will flash you even in the daytime. I do not have the extra wires and I only had the standard 3 wire connection with adapter cords so absolutely no issues ever with them. Don't have any use for halo rings etc so don't pay to have them myself and, unless you spend a lot of money on aftermarket lights, a lot seem to have issues with them.
Old Aug 17, 2023 | 05:48 AM
Thank everyone for the insights and tips. I was able to solve the problem. It seems that as per @Jeff Pillsworth comment the high beam was programmed into my DRL.
I already had an OBDII, but my current program didn't have this option, hence why I was struggling. I downloaded a new software (OBD JScan) which worked perfectly.
Old Sep 22, 2023 | 04:17 AM
derwood8's Avatar
I had this same problem. First, I bought a Procal device to program the JK to only turn signals for drl, that resolved the headlights being on all the time.
second, I wired the halo control box into my turn signal wiring. Now my halos are on whenever my turn signal lights (drl) are on. your halo light control wiring should have 2 wires for turn signal and an extension wire, since the control box will likely be on one side of the jk and need to reach the turn signal wire on the other side. Wire black to turn signal black, red to turn signal power (white with green stripe) and turn signal wire to white with red stripe.
in Canada and several states, law requires vehicles in operation to have headlights on at all times. Totally programmable, but requires that procal device (approx $250)
Works perfectly.
