Hella Black Magic Problem
Old Dec 29, 2010 | 03:35 PM
dutch0182's Avatar
Default Hella Black Magic Problem
I've followed the wiring diagram and my lights aren't working. I have the Red (30) wire connected to the + terminal from the harness, the Black (87) wire connected to the lights from the harness, the Blue (85) grounded from the harness, and finally the Yellow (86) wire connected to the positive black wire running my fog lights. I'm assuming the issue is the Yellow wire but I don't understand why. My fog lights I installed using the factory fog light wiring so I never had an issue. What is wrong with my wiring and what do I need to fix it? I want my Black Magic lights to come on with my fog lights. Any advice?
Old Dec 29, 2010 | 03:48 PM
Orangeav's Avatar
What switch are you running? Did you check your grounds? Did you double check the order of the wires to the switch? Did you power the switch ( that was my mistake first time)
Old Dec 30, 2010 | 05:39 AM
dutch0182's Avatar
I was attempting to run them off my factory fog light harness which already has some hella fog lights working. I checked all the connections and everything is good. Just no power, I'm going to test out some other wiring options today and see what works.
Old Dec 30, 2010 | 05:43 AM
Twelveight's Avatar
Did you check to see if you blew the fuse when you disconnected to old fog lights? Also the first light in the circuit is the drivers side try only that light and see if it works.
Old Dec 30, 2010 | 06:17 AM
Orangeav's Avatar
Originally Posted by Hkx3
40-50watts each is all the factory circuit will handle.
I also own the Hella Black Magic, and Im pretty sure they are 100w each.
Id say you tripped the breaker/fuse. Easy way to check the light is to use jumper cables direct to the battery...if it lights, you have a wiring problem
Mine are 55w each, but I ran them to the supplied switch. I'm not going to be much help here, but x2 on the fuse if you haven't checked it yet!
Old Dec 30, 2010 | 10:16 AM
dutch0182's Avatar
It must have been the factory wiring, I ran both the power and the relay to the battery with a switch and it worked just fine. Thanks for all the advice though!
Old Dec 30, 2010 | 10:28 AM
Twelveight's Avatar
I have my Black magics on the factory fog circuit. No problems on mine.
Old Dec 30, 2010 | 10:54 AM
JK-Ford's Avatar
Did the factory fogs come on when you turned on the switch?
Old Dec 31, 2010 | 06:36 AM
dutch0182's Avatar
No, when I spliced into the fog lights both the fog lights and the driving lights didnt come on. but with only one set running off the wires they worked.
Old Dec 31, 2010 | 06:41 AM
dutch0182's Avatar
Originally Posted by willywaxer1
Always run new wiring for power from the battery to a switched relay which is triggered by the stock wiring. That is the best way to add lights. It only costs a couple bucks more and you will be getting full power to those lights without freaking out the Canbus.
Very true. I wasted 3 hours trying to get those lights to work with my fog lights but after weighing the pros and cons (mainly less power to the lights and a good chance of getting harrassed by the police) I just ran both the power and relay to the battery with a switch coming out of my left speaker. Now I just need a good looking switch and a place to put it.
