Help!!!
Old Feb 5, 2011 | 12:49 PM
tomed13's Avatar
Default Help!!!
I am total lost here!! trying to hook up switch box. I get power to lights , but no power from fuse tap to light switches and no power to 12v outlet here is a diagram to how I wired it. I'm about to pull what hair i have left out.
Old Feb 5, 2011 | 02:52 PM
tomed13's Avatar
Nobody
Old Feb 5, 2011 | 03:07 PM
joe a's Avatar
You can trouble shoot everything with a 12vt test light.
Old Feb 5, 2011 | 03:42 PM
tomed13's Avatar
I did that.....get power to relay to 12v plug but not out...and don't get no power from power tap.
Old Feb 6, 2011 | 08:03 AM
flounder's Avatar
Where is the fuse tap plugged in, is there power at the tap. Is the 12v plug the cigarette lighter that has switched power?
Old Feb 6, 2011 | 08:07 AM
jcs07jk's Avatar
Use a test light and check from battery out. Eventually you'll find where you are not getting the transfer of power
Old Feb 6, 2011 | 10:23 AM
tomed13's Avatar
I tried M8, M7 both the heated seat spots and they had no power from them so I went to a spot that was in use M4 I think, it was acc, ingn. spot and still wasn't getting power out of the tap. I have Light force lights and ordered harness with lights and I noticed it wasn't a harness from light force. It looks like they (who I purchased lights from) had made their own harness and still charged the $60. But anyways I noticed the ground wire from the relay is spliced into hot wire to battery. Is that not right and be causing a ground issue? Oh and yes I want to have the 12v plug on a switch.
Old Feb 6, 2011 | 10:27 AM
tomed13's Avatar
Refer to answer #4
Old Feb 6, 2011 | 10:35 AM
The_Yeti's Avatar
I used... (cannot tell you what fuse) but the fuse that controls the ACC plug on the drivers side that is keyed. i tapped into that fuse...
From what you said it sounds like your not getting power from the fuse tap or a Relay is not wired right?
Old Feb 6, 2011 | 10:38 AM
tomed13's Avatar
here is an updated wiring diagram of how I have it wired up. Does everthing look correct in that aspect?
