Help with Daytime running lights!
Old Jan 21, 2011 | 01:51 PM
1stjeep.ro's Avatar
Default Help with Daytime running lights!
Hi, I recently installed a very nice HID kit (8000k) normal beam/high beam as per instructions. At the end of the install I noticed my fullbeams would flicker. I called up DDM tuning ( where i got them from) and they are very friendly and told me i installed them correctly and that this is a very common issue with the 07 + JKs. Basically i need to buy a resistor and some sort of capacitor and solder them in: easy enough. However They also told me I need to find a way to disable my day time driving lights because i might wreck the hids since the the ECU will not supply enough juice in the day timer lights. If i were to turn on my headlights they would be fine. But just for safety sake I was wondering, since I am also in the market for a programmer to adjust to bigger tires and different gears and such, what programmer would suit my needs in this situation?
Old Jan 21, 2011 | 09:06 PM
Atticka's Avatar
Pickup an AEV Procal unit and switch your daytime lights to the fogs or running lights.
Old Jan 21, 2011 | 09:14 PM
RAINSTATEBEAR's Avatar
Or get the dual batterie tray from Benchmark Designs and use this as an excuse to buy it
