Help please.
Old Aug 21, 2016 | 01:21 PM
SIDsjeep's Avatar
Veteran: Coast Guard
Thank you so much for this. Hopefully the dealer doesn't give me any problems. Once again the forum to the rescue. ✋ thanks jeepers
Old Aug 21, 2016 | 03:11 PM
TreyJK's Avatar
If that dealer does give you issues, check with other dealers. Those mods shouldn't affect anything, just don't show them those mud photos
Old Aug 22, 2016 | 07:15 PM
maxspongebob's Avatar
Originally Posted by SIDsjeep
Ok I know my clock spring is bad. I am the original owner but I never received the notice. It's an 09. Also I don't know how it could be the clocks spring when it does work intermittently.
The only things going through the clockspring are the airbag, cruise control and other steering wheel mounted controls. Blinkers and low beams are not affected by the CS.
That being said, if your airbag light goes on then take it in to be repaired. The dealer will just install a new CS and you will be on the way. If the CS was causing the problem then you are good.
Here is a copy of my recall notice if you have not gotten yours. https://www.jk-forum.com/forums/show...=1#post4231169
