Help w mygig for a 2011 Sahara
[QUOTE=MANGO;24186]Ok jeeple. I need help. I have a 2011 Sahara jk w a factory standard radio. I know it is a high bus so on ebay I purchased a touchscreen mygig radio. They said it ws just plug and play. So I took apart my dash. Removed old radio and plugged in new one. The only thing that works is the screen moves down to allow u to put in a DVD. Nothing else works. I'm so confused. I've read something's about a " lock pick". I have no idea what that is? Help please!!!!
Did you install the GPS antenna.
Lockpick is a separate add on which:
Override Kit for all OEM Equipped Navigation Systems
Unlocks DVD and auxiliary video playback
Fully enables the blocked functions of the factory navigation system
Allows the viewing of DVDs while the vehicle is in motion
Enables the navigation address input while the vehicle is in motion
Controls factory or aftermarket cameras in any gear
Removes restrictions for XM category scrolling, as well as radio and CD player restrictions
Allows Onstar on-screen dialing
It's doing that because that's not a high speed radio, it's a low speed unit. I checked the part number on the tag against the list on wkjeeps.com, and it's definitely a low speed unit, so someone sold you the wrong radio.
USA/CAN- LOW SPEED REN 4758 (30GB)TE=-:Mango:-;3241815]
You have the wrong one. 2011 jeep jk utilizes different types the one you want is REN 4759
Not 4758.
2011: USA/CAN- LOW SPEED REN 4758 (30GB) *Note- The Low Speed REN was not offered as a factory option in 2011 although this system is still compatible with the vehicles in this section. (The Low Speed RBZ was offered as the 2011 factory option)(NA=north America)
2011 Chrysler 200 (NA)
2011 Dodge Avenger (NA)
2011 Dodge Caliber (NA)
2011 Dodge Challenger (NA)
2011 Dodge Dakota (NA)
2011 Jeep Compass (NA)
2011 Jeep Patriot (NA)
http://www.oemautopartsco.com/index....%29%22&sort=3d
Not 4758.
