Hid relay buzzing
Old Dec 20, 2013 | 07:24 AM
Rbzak's Avatar
That's good to hear.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old Dec 20, 2013 | 11:36 AM
nicksabellajk's Avatar
Just noticed something with the hid's, when i turned them on the tpm warning light comes on then goes off, when i switch to high beams the tpm light comes on then goes of and viceversa.
Any suggestions?
Old Dec 20, 2013 | 01:21 PM
Rbzak's Avatar
Any suggestions?
How do u have them hook up? Mine don't do that. But I just have low beams. No high. But I put a diode on the wire going to the switch. I hooked mine like the this picture
Old Dec 20, 2013 | 03:20 PM
Hooked mine up base on the instructions, they are similar to your pictures except they are the components that came with the hid's from OPT7 hid. Harness, cancellars etc.
Old Dec 20, 2013 | 03:33 PM
Rbzak's Avatar
Try just adding the diode to ur system. The diode will keep from back feeding to the cam bus system.
Sent from my SAMSUNG-SGH-I747 using JK-Forum
Old Dec 20, 2013 | 06:16 PM
Sirtreysif's Avatar
What system did you buy? I've had several friends go with cheaper kits and have had nothing but problems. The shop I picked mine up at has installed hundreds and he said JKs are weird some will work just fine without a relay and some need one. Just my .02.
