High beams & fog lights??
Old May 13, 2012 | 03:10 PM
dman1116's Avatar
Default High beams & fog lights??
Has anyone modded their JK to make the fog lights stay on when the high beams are switched on?
Old May 13, 2012 | 03:24 PM
grumpy1's Avatar
no I jsut upgraded my headlights to Hella h4 bulbs and now dont even need the fog lights on with the low beems
Old May 13, 2012 | 04:43 PM
dman1116's Avatar
Into low cost, not paying $50+ for lights when mine work, lol.
Old May 13, 2012 | 05:03 PM
carolinajk's Avatar
i did this on my z28 it involved tapping into the relays and jumping some wiring would be similar on a jeep im sure there are online details just google you will have to remove the tipm to access the wiring and i wouldnt hack up wires on a newer vehicle esp if its still under warranty my car was a 94 and it wasnt as involved electronically as the jks are jmo
Old May 13, 2012 | 05:17 PM
dman1116's Avatar
Yea I had a low/high beam jump on my 97 Chevy 1500, and loved it. It may be as simple as a jumper?
Old May 13, 2012 | 05:57 PM
Redman333's Avatar
I don't know if it's that simple but I'd like to know also if someone can chime in. If no one does I may try to find out myself this week. No time right now though.
Old May 14, 2012 | 07:00 AM
JK-Ford's Avatar
There is only one way. You have to cut them loose and rewire them like aftermarket lighting.
Old May 15, 2012 | 05:24 AM
Redman333's Avatar
I'm assuming because its a computer controlled circuit right? is there anyway to reprogram it using a programmer.
Old May 15, 2012 | 10:34 AM
JK-Ford's Avatar
Only if you know a programmer willing to try and hack your computer. To do so commercially would be illegal.
Old May 15, 2012 | 04:16 PM
JeeP_MarK's Avatar
I haven't done it yet but was looking into taping into the factory switch on the light switch not at the fog light as a trigger for my hid relay kit to see if it still stays on with high beams, it it works any one can buy a $15 relay kit to run the stock fogs or hid kit with high beam on
