Improving Factory sub acoutics
Old May 12, 2012 | 11:11 AM
Toddf73's Avatar
Default Improving Factory sub acoutics
has anyone built an enclosure for the infinity factory subwoofer that has made a difference in the sound? Also, is it possible to add additional subwoofers and an after market amp, while keeping the factory subwoofer functional? Lastly, I had an after market amp installed and the bass was "clipping" or cutting out after the volume was turned up. Any idea what this was all about? I am thinking the installer did not connect something correctly.
Old May 12, 2012 | 02:32 PM
DBTJKU's Avatar
Remove subwoofer and stuff the enclosure with polyfill. There is none in the enclosure.
Old May 13, 2012 | 08:07 AM
Toddf73's Avatar
Did that, not much different thanks though. Going to add additional amp and subs I think
Old May 13, 2012 | 08:10 AM
MoreOvalteenPlz's Avatar
What I did was cut and splice into the sub wires going into the infinity amp and hooked a line out converter to that. I've removed the factory sub anyways but i can still use the factory sub output.
Old May 13, 2012 | 12:17 PM
Toddf73's Avatar
Ok that makes sense thanks. Bypassing the amp but still using the low frequency output. How do you know which wires lead to the bass frequency? What LOC do you recommend? I was looking at the audiocontrol systems
Old May 13, 2012 | 12:37 PM
arjeeper's Avatar
Anyone had any luck using the factory enclosure and just replacing the sub and powering with aftermarket amp?
Old May 13, 2012 | 12:45 PM
Toddf73's Avatar
I have seen on some other posts, people have replaced the factory sub with a kicker speaker
Old May 13, 2012 | 01:20 PM
Jeep Unlimited's Avatar
I did that by installing a Kicker 8" powered by a 5 channel MTX Jackhammer.
Slight improvement over stock but the enclosure sucks and all you're doing is polishing a turd.
I eventually did this and could not be happier -
Old May 13, 2012 | 03:01 PM
dman1116's Avatar
My buddy is a sound engineer and he adjusted my audio for me;
He put the fade to the rear @ level 5,
treble @ 5, bass @ 4, mid @ 0-1
I think it sounds great, hits hard enough to shake all 3 mirrors....
Old May 13, 2012 | 04:45 PM
SB5700's Avatar
Here's what I did on my 2012 Sahara
Replaced the Sub with a Kicker 8-inch unit - dual voice coil - stuffed the cavity with batting - Crutchfield = $80;
Installed a Polk Audio amp (200 watt, I think) - just to drive the sub - Put it in the well in the back - Speaker-level inputs - it has voltage sensing feature (no remote wire needed). - Brandsmart USA = $120
The most difficult part of this was running a new power wire from the Fuse block to the Amp.
This produces a much better bass profile.
