Infinity Sound System (factory installed) need answers
#23
i dont think so. from what i heard on the forums it is not worth the money. I got the nitro amp from here and works for me:
http://www.moparpartsamerica.com/par...layCatalogid=0
price went up i got mine last year for $125. another alternative i would think is you could remove the infinity system all together and look go for a separate amp or look at the Alpine KTP-445. It's constant 45 watts RMS:
http://www.alpine-usa.com/product/view/ktp-445
#24
Since we are talking about the infinity system......where is the crossover for the tweeters? I thought i remember reading different threads that said different things. Is it done by the amp or does the tweeter have a built in crossover. If it is done by the amp, will the nitro amp do this as well?
#25
The amp itself does the x-over. So if you get a component speaker set, just use the included component x-over on the tweeters only. I have polk db component on mine and sounds way better than the stock pos
#26
If the amp is doing the crossover on the factory speakers why wouldn't it do it for aftermarket speakers? Assuming you are using the stock wiring.
#27
it will. i just used the included x-over that came with my component set as an extra level since it crosses over at the recommended specs to those tweeters. i may or may not have done the 'correct' thing and im sure someone may say i should not use a crossover if something is already crossed over. But to me, it sounds alot better. i tried my aftermarkets without the crossover on the tweeters and it sounded like @ss, plus the volume was kinda low. try it out 4 urself and see what u think. My theory was that on the aftermarkets, there is a gain level on the included crossover and i put mine all the way up, with the freedom top panels removed, i can still hear the music great at 75 mph.
