Installing New Speakers
I replaced all my speakers like a month after I bought the Jeep. The speakers should come with wires and the connections for them. I cut off the speaker harness and spliced in the new wires to the existing wires using butt connectors and it sounds great! There is a wire color chart somewhere on the internet. I googled it and found it pretty easy. What speakers did you get and are you changing the Head Unit?
Thanks. I was thinking of splicing the wires and soldering to the factory wiring - although I'm not sure if I want to change the wiring later.
I got Polk MM6501's for the front and Polk MM 651's for the soundbar. I will be replacing the head unit at some point, but for now I'm just swapping out the speakers.
I found this on another forum... so this is what I'm going to go with. Hope this helps others as well.
Front Left:
Gray/Violet + (Green)
Gray/Yellow - (Red)
6.5 inch round speaker, 4 inch maximum depth
Front Right:
Dark Green/Violet + (Green)
Dark Green/Yellow - (Red)
(Colors in parentheses are for the factory speaker pod internal wiring.)
Rear Left:
Black/White +
Dark Green -
6.5 inch round speaker, 3.5 inch maximum depth
Rear Right:
Light Blue +
Light Green -
Front Left:
Gray/Yellow - (Red)
Front Right:
Rear Left:
Black/White +
Dark Green -
Rear Right:
Light Blue +
Light Green -
I am going to buy the same speakers... are you running the infinity system?
I have an aftermarket head unit, pushing about 20 watts RMS and 50 watts max... I have the infinity amp pushing whatever and to be honest I do not think thats going to be enough to push the speakers if I just swap them in... I am thinking because of this of adding an 4 channel amp... so I can rock something around 75 watt RMS due to the specs on the speakers...
When are you doing the install ??
AHH whopse ****
looks like wrong model POLK AUDIO DB651S 6.5" + DB6501 6.5" is what I am doing...
AHH whopse ****
Last edited by joey2times; Jan 13, 2012 at 12:37 PM. Reason: wrong moddel speakers...
You likely want to check out what the stock head unit is putting out too...
those speakers are 3 ohm's
I was pretty sure stock was either 2 or 4 ohms.
for what its worth:
ht tp://www.crutchfield.com/App/Product/CompareTo.aspx?compareItems=01|107MM6501&compareIt ems=01|107DB6501&g=52000
for what its worth:
AHH whopse ****
AHH whopse ****
My speakers got in last night, so I'll be doing the install this weekend (hopefully tomorrow). I'm putting Polly Fill in everywhere and using Dynamat on the soundbar to cut down on vibrations.
As far as the rest of the audio system, I have the stock head unit without the Infinity amp. I do plan on replacing the head unit and amp at some point, but I'm trying to hold off on the head unit given the way they seem to be going at the moment - I may just settle for a cheap head unit and get a nice one later. I also plan on adding a sub in the future.
As far as the specs on the speakers the 6501's and 651's both have continuous and peak power handling of 125 w and 250 w, respectively.
I know it won't sound as good as it could, but at least it's better than what's currently in there.
