Installing Rigid Industries Duallys
Old Aug 13, 2013 | 02:27 PM
bobafetske's Avatar
Default Installing Rigid Industries Duallys
I have never done anything like this and have no Idea where to start. I'm mounting them at the base of the windshield. Just have no idea at all as to installing the off/on switch. Any help would be much appreciated. Thanks
Old Aug 13, 2013 | 03:46 PM
DETECTIVE1108's Avatar
On my 2013 JK, I used a Daystar switch panel that replaced the lil panel with the net just in front of the shifter.. Very clean and will hold 6 rocker switches.
Old Aug 13, 2013 | 04:43 PM
Cajn1's Avatar
There is a ton of room behind the plastic piece over the A-pillar to mount a switch. There are pretty clear cut instructions included with the lights on how to use the plug and play harness.
Old Aug 13, 2013 | 04:51 PM
Cajn1's Avatar
This is where I located my switches...
Old Aug 13, 2013 | 05:00 PM
Mountainneer's Avatar
Check out sPod. Well worth the money.
Old Aug 13, 2013 | 05:20 PM
fultonromero12's Avatar
I just finished installing these. Replacing some hella 500 on the windshield. This was by far the easiest install ever!! Plug and play! I just drilled a hole on the plastic under the steering wheel for the switch. It's dark but will try to post pic tomorrow
Sent from my iPad using JK-Forum
Old Aug 13, 2013 | 05:51 PM
oofogbp's Avatar
2nd the sPod - best thing Ive installed to date
not that i have a long list of upgrades so far
