interior dome light
hi
i was looking to replace the two lights on the sound bar and roll bar with LEDs so i can leave them on longer without draining the battery. anyone know how to remove the bulb or have the bulb specs? anyone done this? if so is it any brighter? pics would be very nice
thanks
thanks
Great idea. I do not know any specs on the bulbs. But I can tell you a little about LEDs. They use less power, because the light is more directional. So you end up with very bright, directionally localized lights. An example can be found in looking at all the cars with the LED tail lights.
That being said, you can find applications of what you are talking about on sailboats. Often they need low power lights to read charts etc.
hi
thanks
thanks
Now the rear one is a different story. There needs to be a minimum draw on this one, or it doesn't light up, or flashes like crazy. I used another 4210-WHP6 here -- it flashed until I added a resistor. I forget the strength of the resistor though. I tried a few and they all worked, so used the lowest amperage one I had.
js.
js.
w w w . o z n i u m . c o m They are super bright, look killer and they are known for great products.
Get there Dome light...it is a universal kit that comes with a bunch of dummy bulbs and a flat LED strip...they are sick I had them in my BMW, and I just ordered a set for my new Jeep.
If you want the part number for the bulbs I think it is a 194 not sure just go to Sylvania's site enter year make and model and they will tell you the size of every bulb in the whole rig. Which should make doing a full blown LED swap a breeze.
