Interior lights to dim!!!
Old Mar 16, 2014 | 03:06 PM
mark_c's Avatar
Default Interior lights to dim!!!
Anyone have any aftermarket interior lights. At night time when I turn them on I can't see anything!!! I have been thinking about popping off the cover of the light and rigging some LEDs in there or installing them in the sound bar. Not too sure yet what I want to do. Any ideas or write-ups?
Old Mar 16, 2014 | 03:36 PM
Croce's Avatar
https://www.jk-forum.com/forums/jk-w...olution-40202/
also google "interior lights site:jk-forum.com" without quotations and you'll get a lot of results
Old Mar 16, 2014 | 05:45 PM
bfdengine5's Avatar
I actually just upgraded my interior lights after I saw what a buddy of mine did with his. In my JKU it cost all of $35 and the amount of light they now throw is amazing!! They are called "Type S" or "S Type". It is a LED board that has 20 individual LED's on them. Picked them up from autozone. It comes with an "adapter" bulb that you plug I to where the normal bulb would go, has a wire that comes off and plugs into the LED board. The LED board rests nicely in the dome cover, and seems to disperse the light even more than the stock bulb. It's also a hell of a lot brighter!! Each set-up is about $17 before taxes (only need one if you have a 2-door). They don't seem that bright in the store, but believe me when I say these work amazing.
Old Mar 16, 2014 | 08:52 PM
Rkelley's Avatar
I ordered a kit from North Ridge 4x4, It was like 25 for my JKU. IT makes a WORLD of difference.
JK Interior LED Replacement Bulbs
Old Mar 17, 2014 | 04:45 AM
mark_c's Avatar
Cool thanks for responding!
Old Mar 17, 2014 | 11:48 AM
WranglerJA's Avatar
Default Bright Light!
Also got mine from Northridge4X4.
Putco JK 2010-14, 4 Door, LED Dome Light Replacement Kit - 980295
Im sure there are cheaper options. They are super bright so hoping the JK's have a dimmer switch to turn it down
Old Mar 17, 2014 | 12:46 PM
jk_sea's Avatar
Do the Putco's put out a lot of heat? Is there any modification required to get them to work or fit correctly?
Old Mar 17, 2014 | 01:49 PM
Sand Scorpion's Avatar
LED Lights, Bulbs & LED Lighting Accessories - SUPER BRIGHT LEDS
Old Mar 17, 2014 | 03:43 PM
Rkelley's Avatar
LED's generally don't put off a lot of heat.
Old Mar 17, 2014 | 04:06 PM
BossHog's Avatar
Originally Posted by Rkelley
I ordered a kit from North Ridge 4x4, It was like 25 for my JKU. IT makes a WORLD of difference. JK Interior LED Replacement Bulbs
X2. Give it a shot. Cheap mod but looks cool and great functionality.
