Isolation Switch?
Old Aug 31, 2010 | 06:32 PM
stevedolce's Avatar
Default Isolation Switch?
what's an isolation switch? i'm reading the ARB compressor 101 and someone mentioned use of an isolation switch. is taht a fancy term for the switch that comes with the ARB?
Old Sep 1, 2010 | 05:46 PM
Davebone42's Avatar
if you havent already figured this out i will throw in my .02
the isolation switch is used to make the only way to lock the front locker is when the rear locker is locked.
it is a safety deal
Old Sep 1, 2010 | 06:43 PM
ronjenx's Avatar
An isolation switch could be used to make a compressor or winch run on the extra battery only, thereby not running down the service battery.
Old Sep 1, 2010 | 06:50 PM
Serg5000's Avatar
Sooooo an Isolation switch............................................ ............................. Isolates?
Old Sep 1, 2010 | 07:04 PM
stevedolce's Avatar
Default ok---
what's the difference between the switch that i installed for my fog lights and an isolation switch?
Old Sep 1, 2010 | 07:12 PM
PainKiller's Avatar
as far as install, it seems the ISO switch is wired as the on/off for power to the ARB compressor, the other wiring harness it comes with goes to the front and rear locker switches.
