Jeep Wrangler infinity sub in non infinity 2008 jeep wrangler
I was wondering if I bought a Jeep Wrangler infinity subwoofer box, would I be able to install that to my 2008 Jeep Wrangler non infinity?
You cant just "add" it to the stock system unless it was shipped with a subwoofer already installed.
The stock systems have no amplifier and the wiring harness is not connected to anything, even though there are wires in the back corner of the Jeep AND there is no way to add a FACTORY amp and sub retroactively to the standard stock system.
You can buy an Infinity sub and add it to any sound system, but you will need to tap into a speaker wire with an LOC and use an aftermarket amp. Overall it's a bad idea because the factory Infinity sub is a a piece of paper junk. If you go ahead and do it, you will need to find an amp that is no more than 75-100w into 4 ohms (2 2ohm voice coils) or you will blow the speaker.
The harness is there but not attached to anything? I have an 09 Sahara unlimited. I found this post while looking for options for installing a sub in the jk. Being a Sahara edition, I assumed that it came with the factory sub. The harness is definitely there. I was hoping to use it for the line out, power on and control from the factory head unit. Is this Possible? I have several powered subs to choose from ( my bro collects steep junk like I collect jeep junk)
Other than wiring it up with a full Sub wiring kit, is there a way to use the factory harness and just run a power line from the battery?
