JKU backup camera install for $110
Old Jun 6, 2019 | 12:35 PM
rasonics's Avatar
Default JKU backup camera install for $110
I got some good information from this forum and others that helped me install a backup camera on my 2017 JKU. Sharing information and returning the favor...
I must say that the install was relatively easy thanks to videos and posts. The only time consuming part was where I installed the camera. After considering installation on a number or buying a bracket, I ended up making my own mount for the best camera angle. It took me 2-3 hours to install but it could have been less if I didn't have to drill holes and mont the camera the way I did. I now only need to clean the mount because I used all the rubber washers that came with the camera to change the angel up.
Here is what I bought (hardware and software).
1. JScan software 1 VIN license $18.00 (App Store) - Used it to unlock the radio and change many other settings on my Jeep.
2. vGate ODB port adapter $29.99 (link) - This ODB adapter works with Jscan
3. Radio video harness $19.99 (link)
4. Camera (came with all required accessories for installation) $39.99 - (link) - Could've bought a $10 camera but this one is ip69k and nice quality.
Total: $108 + hours of research + installation time.
Videos that helped with the install:
Radio Removal:
Wiring (automatic or Manual):
Old Jun 7, 2019 | 02:12 AM
Ghost JK's Avatar
5 Year Member
Looks good. Did you actually mount the camera to the centercap? So if you ever had to use your spare, you would need to remove the cap to move the tire off the mount?
Old Jun 7, 2019 | 06:45 AM
rasonics's Avatar
That was the tricky and time consuming pat of the install. Camera connects to the extension wire with a four pin connector. I have teraflex HD spare mount. I drilled a hole in the spare mount plate that is behind the centercap which enabled me to fish the extension wire all the way inside the centercap and connect the camera to extension wire. If I have to change the spare tire, I will just open the centercap, disconnect the four pin connector, and use the same centercap where camera is mounted. Will post a picture later...
Old Jun 13, 2019 | 11:03 AM
hivoltagedriver's Avatar
I've been looking at adding one myself. I've heard good things about that JScan ap. I'll need to jst get it done. Thanks for the write up.
Old Jun 13, 2019 | 12:54 PM
JacKed 8's Avatar
Ingenuity - one of the reasons I joined this forum years ago when I bought my first JK. Love seeing people come up with cool ideas like this. Clean look man.
