Kicker PT10 BassStation Install
Hey folks:
I just finished installing the kicker PT10 BassStation on my gate door. Thought I would share with everyone in case you are thinking of the same thing. The BassStation is a great little bass that has a built in amp AND comes with a gain remote control (so needed when you need to adjust for top up or top down). Got it for $250 at Best Buy with the 4 year warranty for $32.
I highly recommend the 4 year warranty because if the amp goes you also lose the speaker or vice versa. For a total of $300 its still cheaper than buying the units separately.
BassStation with Gate open
Installed BassStation with Gate closed
Remote Control on driver side seat.
Why so harsh?! Not all of us like bass so loud you can set off car alarms. I think the infinity sub sounds amazing for what it is and what its in. It's no 1000 watt aftermarket sub, but it's all I'll ever need. Not to mention less for people to steal. All I did was change the head unit to a navi unit and everything is perfect!
I am thinking of doing something similar but does the stock head unit in an x have the coax plugs for the amp built into the back? i have not taken mine out to check. Thanks
Sent you a PM too, but would you care to give a little more info? Like exactly how its wired, do you use the stock Infinity wires? Also, how exactly is it mounted? Thanks.
I strapped the bass to the gate door with the straps and screws that came with it. The bass instructions show hownto drill to the floor. I simply drilled to the gate. I also bought two vey large L shaped braces that i drilled to the gate and had the bass sit on it for support.
The install is solid til today with abuse from my kids. The sound is great. My buddy was amazed how sharp the bass was.
Very happy
