Kicker PT10 BassStation Install
Old 06-27-2011, 01:04 PM
shrimpster's Avatar
Default Kicker PT10 BassStation Install
Hey folks:
I just finished installing the kicker PT10 BassStation on my gate door. Thought I would share with everyone in case you are thinking of the same thing. The BassStation is a great little bass that has a built in amp AND comes with a gain remote control (so needed when you need to adjust for top up or top down). Got it for $250 at Best Buy with the 4 year warranty for $32.
I highly recommend the 4 year warranty because if the amp goes you also lose the speaker or vice versa. For a total of $300 its still cheaper than buying the units separately.
BassStation with Gate open
Installed BassStation with Gate closed
Remote Control on driver side seat.
ID:	176065   Click image for larger version
ID:	176067   Click image for larger version
Old 06-27-2011, 01:46 PM
Zroe's Avatar
How does this compare to stock infinity sub?
Old 06-27-2011, 02:14 PM
shrimpster's Avatar
Kills the infinity sub....but most aftermarket subs do. Its a really good sub. Very impressed. I'm not a big bass guy so this is perfect for most of my music.
Old 06-27-2011, 10:14 PM
Originally Posted by ludski
stock subs are jokes. no matter the car. so you cant compare anything to them.
Why so harsh?! Not all of us like bass so loud you can set off car alarms. I think the infinity sub sounds amazing for what it is and what its in. It's no 1000 watt aftermarket sub, but it's all I'll ever need. Not to mention less for people to steal. All I did was change the head unit to a navi unit and everything is perfect!
Old 06-28-2011, 10:19 PM
KT'S-JK's Avatar
I am thinking of doing something similar but does the stock head unit in an x have the coax plugs for the amp built into the back? i have not taken mine out to check. Thanks
Old 10-07-2011, 02:13 PM
Zroe's Avatar
Sent you a PM too, but would you care to give a little more info? Like exactly how its wired, do you use the stock Infinity wires? Also, how exactly is it mounted? Thanks.
Old 10-07-2011, 03:02 PM
shrimpster's Avatar
I never had the Infinity system. I had custom kicker speakers and an amp installed prior. I used an RCA convertor to convert the right and left speaker wires fro the headunit to RCA for my AMP. The bass came with stereo speaker wires. I had to buy the kicker RCA convertor to switch those to RCA and then attach it to the RCA from the headunit. Note that i got RCA splitter wires so the headunit RCA would connect to my AMP and BASS.
I strapped the bass to the gate door with the straps and screws that came with it. The bass instructions show hownto drill to the floor. I simply drilled to the gate. I also bought two vey large L shaped braces that i drilled to the gate and had the bass sit on it for support.
The install is solid til today with abuse from my kids. The sound is great. My buddy was amazed how sharp the bass was.
Very happy
Quick Reply: Kicker PT10 BassStation Install
