Kicker Sound Bar Speaker Kit at Quadratec
Old Jan 16, 2008 | 09:47 AM
jckid's Avatar
Default Kicker Sound Bar Speaker Kit at Quadratec
Has anyone tried the Kicker Sound Bar Speaker Kit that Quadratec is selling? Here's a link: http://www.quadratec.com/products/14133_202.htm
I am happy with my factory sound system, except for the sound bar speakers because they are barely audible. I think I read somewhere that Jeep wired them in such a way so that they won't go loud, because of distortion issues or something. So would this Kicker replacement kit make any difference at all?
Old Jan 16, 2008 | 10:06 AM
wayoflifette's Avatar
JK-Forum Founder
There is a pretty long thread about it here:
https://www.jk-forum.com/forums/sponsoring-manufacturers-vendors-check-out-cyber-monday-specials-24/kicker-factory-replacement-overhead-sound-bar-speaker-kit-19726/
Old Jan 16, 2008 | 10:14 AM
jckid's Avatar
Thanks! I did a search, but obviously I didn't do a very good job!
Old Jan 18, 2008 | 10:17 AM
freeswimmingfish's Avatar
If you only replace the rear speakers, then no, it will do almost nothing. The issue is with the factory head unit. I replaced my HU an all 4 speakers, made a HUGE differance. I also stuffed the soundbar and front speaker "pods" with lots of pollyfill, it did dampen alot of the vibration.
Old Jan 18, 2008 | 06:11 PM
wayland1985's Avatar
Polyfill is supposed to be used to make an enclosure seem bigger for a speaker. It's not designed to dampen vibration. Maybe you should buy a gasket to dampen the vibration instead???
Old Jan 18, 2008 | 08:42 PM
Correct, but the "side" effect was that the soundbar did not vibrate as much than it did without it.
Old Jan 19, 2008 | 12:02 PM
Hoovis's Avatar
Jckid, just a quick thought, but if you say your soundbar speakers are barely audible, have tried the front/rear fade adjustment? I did replace all my factory speakers with some Polk db651s's, but the factory soundbar speakers were still plenty loud (just not as clear and had zero bass). So I suspect you might simply need to adjust your fade.
It is the same place as bass, mid, treble, balance, etc. The last one is front/rear fade. Try that by pressing the right control knob while the stereo is on. Hoping that is your problem, because I don't know why else your rear speakers would be barely audible.
Old Jan 19, 2008 | 02:11 PM
150's Avatar
150
Fallen Hero
I was thinking about replacing my head unit with the "Alpine CDA-9886" Do you think this will make a big differnce or is it not worth the money?
Old Jan 19, 2008 | 08:23 PM
Yamaha90's Avatar
i like to feel surrounded by sound, so i have my fade set at -2 or -3 so it puts more oomph into the back a little, but i only have the stock speakers..which are crappy.
Old Jan 20, 2008 | 03:12 PM
For some reason the factory setup leaves the rear speakers much quieter than the fronts. So I'm sure that's what he's alluding to. I don't think it's a fader issue so much. Even mine, with the fader adjusted just didn't have enough power to the rears.
I think any aftermarket head unit would really improve the performance of the sound system. But again, it'll only sound as good as the speakers allow it to. I noticed quite a difference when i upgraded mine, though.
