Led Replacment lights
Hey guys,
I have a 2011 2door Jk and would like to install some led lights to replace the dome and fog lights. What have you guys done to do this and which bulbs did you use? I am a bit paranoid that the canbus system will make it hard to do. Have any of you had troubles with this? Any help would be much appreciated!
There are hundreds, if not thousands of posts on this topic, on this site and others. All you have to do is use the search function (thus avoiding duplicate postings on the same topic).
But to answer part of your question, for interior dome lights, I installed Putco 280003W Type T in the front dome light and Amico 43mm Canbus Error Free in the rear dome light; both are compatible with CANBUS and draw no current when "off".
