Left KC slim light out?
I installed my KC slim lights and after a couple months the left light won't turn on, the right side is fine. The light doesn't look burned out, and don't really want to rip the wiring all apart. Anyone have this issue?
check the bulb... one of my light wouldn't turn on and after checking fuses, wireing, relay and switch i check the light and yup a broken filament, it didnt look burned out but it was ...
Check the voltage at the light (using the disconnects provided by KC). If you have voltage there then it's the light or the wiring within the light. If not then trace your way back. You could also just connect the wires from the working light to the non-working light, to see if it works. Good luck!!
