Light bar causing soft top buffeting...ELIMINATED!!!!!!
Old Jul 18, 2014 | 05:44 PM
8000ft's Avatar
I should add that when the location is finalized I will drill a small hole thru the fin and a smaller hole in the plexi, then I will tap the plexi for a #10x 32 screw. I figure that i will only need the plexi in the summer so when the soft top comes off in the fall I will pull the plexi off also. No need to have a shelf for the snow to build up
Old Jul 18, 2014 | 05:47 PM
zong4200@gmail.com's Avatar
Great thank you for the info. I will have to try this before my 13 hour drive to Co.
Old Mar 28, 2017 | 05:09 PM
Reinier1011's Avatar
Post Quick Questions
Did you make or buy the bracket? If you did where did you buy it from? Is the reinforcement necessary?
Old Mar 29, 2017 | 08:03 AM
mglad1's Avatar
That's nice... I did a similar fix but used a piece of aluminum that was a nice snug fit between the fins.
Old Apr 11, 2017 | 01:10 PM
ktmjr's Avatar
Did that get rid of the buffeting of your soft top by itself, or did you also do some type of adapter brackets to reposition the light bar?
Old Apr 11, 2017 | 02:14 PM
mglad1's Avatar
I only used the original bracket but it had 2 options for positioning the light bar. I simply did trial and error to see which one worked for me.
Old Apr 11, 2017 | 02:32 PM
ktmjr's Avatar
Default any buffeting, or it just made it tolerable?
Nice! And the buffeting is completely gone? Like you can drive at interstate speeds without any buffeting, or it just made it tolerable?
Old Apr 11, 2017 | 03:06 PM
mglad1's Avatar
Yes I love the light bar now I was contemplating dumping it when I was able to figure it out. I work at a local airport so I had the benefit of being able to make adjustments the run it down the runway to test it again. That helped a lot. To fine tune things.
Old Apr 12, 2017 | 05:21 AM
ktmjr's Avatar
For sure having an airstrip right there would be a huge help! I'm still playing around with adjusting it, but just haven't found a sweet spot yet that really gets completely rid of the buffeting like when the light bar is removed, but I'm hoping adding a fin like you did may do the trick. I really don't want to get rid of the light bar, but I also drive between FL and GA a few times a year and the way it is right now would be intolerable for an hour on the interstate, never mind 8 hours!
But I'm glad to hear you were able to stop the buffeting entirely. That gives me hope so I'm not going to quit trying yet! Thanks!
Old Apr 14, 2017 | 07:09 AM
cjnomo's Avatar
Try turning on ur a/c or heater. Forcing air into to the cab does a decent job in equaling out the air pressure differences. When I'm on the hwy and I get buffeting, turning on the air nearly cancels it out. Either that or I just crank the radio. Both in conjunction works for me every time.
