Lights ON?
Old 10-27-2016, 06:54 AM
augichef's Avatar
Default Lights ON?
Came out this morning to find my LED A-Pillar lights turned on, I figured that it must have gotten bumped on accidentally. I went to turn them off and found that my otrattw switch was in the OFF position, so now I'm at a loss..
About a month ago I found that my pillar lights would not turn on so I chased all my wires and connections only to find that the relay was the problem. Digging through my extra parts bin I found that I had a relay so I swapped it out and it fixed my problem, it functioned like it normally did.
But...Today has me totally stumped.. I pulled the fuse off so that I can shut the light off..
Any and all help would be greatly appreciated..
thanks in advance,
Augi
Old 10-27-2016, 07:48 AM
Canvas's Avatar
You might have a bad relay. That is the only thing I can think of.
R/
Will
Old 10-27-2016, 08:03 AM
augichef's Avatar
how would I go about testing the relay
Old 10-27-2016, 08:17 AM
Canvas's Avatar
I would try doing an ohm or continuity check. I am not that savvy on electrical but that is my best guess.
Old 10-27-2016, 08:46 AM
Canvas's Avatar
Check to see if you have power coming off of pin 86. Here is schematic that might help.
Old 10-27-2016, 09:01 AM
Former Vendor
So-Cal4x4's Avatar
Try swapping the switch with one of the other switches. It could be internally shorted in the switch. Another issue could be that pins 1 and 2 on the switch are swapped ( but this probably is not you issue since it just happened).
Old 10-27-2016, 09:16 AM
jchappies's Avatar
give the relay a love tap.....bang it on something then try it again sometimes they just get stuck
Old 10-27-2016, 09:45 AM
augichef's Avatar
Will do...
Old 10-28-2016, 07:47 PM
augichef's Avatar
Finally had a chance to check the relay.. well I tapped it with a mallet it would works here and there, so I bought another relay tonight to replace it. It works as it should now.
Thanks everyone for all the advice
Augi
Quick Reply: Lights ON?
