Limp mode status if three things are done
Hi, I have been dealing with this issue since we replace the 2.8 L engine.
3 things triggers the limp mode:
we have ground test the cables we think are common between the brake switch, the ignition key and the transmittion an apparently there is no problem.
what else should I check?
- placing the key in accesory position.
- placing the key in run (without starting the engine) and pressing the brake pedal.
- when driving without the limp mode on, if I change gear with the shifter (automatic transmission) to second, it goes to limp mode.
