Mounting a sirius radio antenna on a jk?
Old May 12, 2012 | 01:16 PM
psychotic_fox92's Avatar
Default Mounting a sirius radio antenna on a jk?
so i've got the sirius radio magnetic mount antenna, i tried putting the wire through the hole on the drivers side so i could mount the antenna on my hood, but the plug at the end of the wire was too big to fit through. right now i have it mounted inside but my radio cuts out alot, i put it on top of my hardtop just to see if it'll still cut off, and it worked fine. so bottom line is i need to figure out a way to mount it outside the jeep.
anybody have any opinions of where i could put it? i was thinking about trying to attach it to the tailgate next.
Old May 12, 2012 | 01:38 PM
desync0's Avatar
The factory antenna is a magnet mount as well, it mounts over the passengers head on the sound bar.
http://www.quadratec.com/Assets/Installation/75781.pdf
That's a link to the mopar installation manual for the mopar kit at quadratec. Looks like a pain in the ass, but it's a great location and it's completely hidden!
Old May 12, 2012 | 01:51 PM
JK4x4wrangler's Avatar
I mounted mine over the sound bar/roll bar no problems with service or signal.
Old May 12, 2012 | 02:04 PM
well i had it tucked under my dash, so i'll try putting it on top of the roll bar and see if it helps.
Old May 14, 2012 | 07:14 AM
EVD's Avatar
EVD
Put mine on top of the windshield on the metal. Ran the wire down the driver side a pillar. working well so far.
Old May 14, 2012 | 07:27 AM
isolated1523's Avatar
I WILL fit through the hole...take a wire coat hanger and work a bunch of the foam out to widen the hole. Then tape the coat hanger to the end of the antennae and push it through...took me a while, but i finally got it.
-Adam
Old May 14, 2012 | 07:32 AM
AHunter's Avatar
Here is where the factory one mounts, I installed mine here and have had zeros problems.
Old May 14, 2012 | 03:07 PM
alright so i tried mounting it on the roll bar but it still cuts out, i figured my hardtop must be interfering with the signal somehow.
so today i ran the wire through the tailgate and mounted it next to my tire carrier, the same way i did it with my cb radio coax cable, so hopefully it works now.
Old May 18, 2012 | 08:10 AM
maple75's Avatar
Mounted mine on top of roll bar underneath padding. Works fine even with hard top on
