My LED dome light and reverse light upgrade PICS
Old Nov 4, 2012 | 12:20 PM
  #51
sbacpo's Avatar
Originally Posted by notsoricer
Here's the breakdown of what I ordered...
2 | 3157-x45-T: 3157 LED Bulb - Dual Intensity 45 SMD LED Tower| $ 24.95 |
3157-W45-T: Cool White
1 | 4210-xHP6: 6451 LED Bulb - 6 SMD LED Festoon| $ 14.95 |
4210-CWHP6: Cool White
2 | WLED-xHP6-DAC: 194 LED Bulb - 6 SMD LED Wedge Base DAC| $ 11.95 |
WLED-CWHP6-DAC: Cool White
here's links...
http://www. superbrightleds.com/moreinfo/tail-brake-turn/3157-led-bulb-dual-intensity-45-smd-led-tower/633/
http://www. superbrightleds.com/moreinfo/festoon/6451-led-bulb-6-smd-led-festoon/662/
http://www. superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-6-smd-led-wedge-base-dac/213/
Thanks for the links.
Old Nov 5, 2012 | 07:33 AM
  #52
flienlow's Avatar
OP-
Can you please update this with the Resistor you bought?
PS. A big thanks for all of your efforts!
Old Nov 5, 2012 | 12:02 PM
  #53
notsoricer's Avatar
Originally Posted by flienlow
OP-
no problem.. heres the part number: RL-2525
Old Nov 7, 2012 | 06:31 PM
  #54
flienlow's Avatar
SHUT THE FRONT DOOR! This mod is awesome! Just what my dome lights needed!
Old Nov 10, 2012 | 05:07 PM
  #55
salmonaediot's Avatar
I just ordered a set. Thanks for your work on this. Nicely done!
Old Nov 16, 2012 | 04:40 AM
  #56
jjmmagoo's Avatar
I don't have the specs in front of me but I used the one off of superbright LEDs.com
Just bought a pair of done lights from them. Fast an easy. I have a 2009 JK and the only issue is that the front done light is barely lit when I leave the car. It's hardly noticeable but if you look carefully its drawing some power. The back dome light does not seem to be doing this. Is this a possible problem??? I hope not and don't think it is considering how little power they draw when they are on. I also replaced my fender lights and will be replacing the parking lights. The only thing left to transform my JK into full LED is the parking light and the brake lights.
Thanks for your info!!!
Old Nov 26, 2012 | 05:08 PM
  #57
Many thanks to the OP for putting this info together. I grin every time I open the door and see those bright LEDs. Nicely done!
Old Nov 26, 2012 | 05:19 PM
  #58
notsoricer's Avatar
Hmm I don't think it's a problem but you can always throw a resistor in there to see if that helps. It'll make the system think you are running a regular bulb in there and the side effects from LEDs will be diminished.
Old Nov 27, 2012 | 06:21 AM
  #59
jjmmagoo's Avatar
Thanks for the reply. I dont think its that big of deal either. But wanted to make sure. Thanks!
Old Nov 28, 2012 | 10:54 AM
  #60
Knightpredator's Avatar
Ordered my Dome and reverse lights today. Thanks for the write-up.
