My System is done....for now :)
#111
Should i pay?
My local shop "Foss Auto" Told me they'd build it for: 150 Materials and 500 Labor. 650 BUCKS WOWZERS! These guys probably the best box builders around. Other places I've looked out look like shit or the customer services is shit. Too much? Comments concerns? Thanks
#112
Welcome!!!!
Good Afternoon,
I am taking the time to introduce myself as well as provide some information that it seems many of you will appreciate. I am new to the site and have have used this post to motivate me to sign up and write.
I currently own a 2009 Jeep Wrangler Unlimited for about a month now with 35" pro comp Extreme AT tires, 18" XD rockstar rims (black of course), 3" tera flex lift, smittybilt side steps, and Pioneer AVIC Z-110 navigation w/ rear view camera.
I was also currently in the process of figuring out sub and amp placement when I found this post.
These photos are an extreme help to me as I was in the process of creating the same subwoofer set up. I am also in the process of measuring the dimensions and creating a 3D image from PRO Engineer for people to reference.
I will keep you posted and provide pictures as soon as I can, it might be a few weeks as it takes some time.
Thanks and appreciate the wonderful site, especially for a 28 year old kid who LOVES his new JEEP!!
#113
box is currently being built, but instead of 10s they're going to fit 12s. Now just to get a good shallow mount 12s.
in the meantime while they are fitting it to my jeep. I will be driving this sexy red cavalier
#116
has anyone else tackled the pioneer custom dash install? I think it looks 100x better than the plastic kit but im not sure if i have the skills to pull it off. Id hate to ruin my dash. Any one try this since?
#117
I have never done it for my jeep mainly because I feel it is off balance from the rest of the car.
I am a symmetrical freak
but I have worked a few custom dash pieces for dodge rams so that you can put a 7" screen in them rather than the stock block with micky mouse ears. It is not very difficult and if you just play around with some bondo for 30 minutes before sticking it on your dash I'm sure you will do a fine job.
#118
#119
Make sure you rough up the plastic with sandpaper before you stick bondo on it really good. Clean it with tackrags too. IMO you need some bracing in there too behind the bondo, I use little pieces of wood glued into place. Good luck, take your time, and show us some pics!
#120
here is my TJ double-din install after it started to crack. It took just over a year to go from perfect to cracked like this. Make sure you brace the bondo carefully. I am no pro... but I have done this before. First time I had it crack like that. Im not trying to scare or discourage you, just recommending you take your time.
