MyGIG RER Software Update 2.042
Old Jul 1, 2009 | 10:00 AM
  #111
armandov99's Avatar
Originally Posted by whpony96
Thats the problem windows will not allow you to burn the disk in the correct format. Download Nero and it has a 30 day free trial then follow the instructions. Don't give up bud you can do it.....
I burned in windows just fine. Just right clicked, send to > cd drive. Then go to the CD drive in my computer and burn it, it is way easy. Worked just fine I'm running the new software.
It's probably more about the folder structure and file locations than about using Nero.
Old Jul 1, 2009 | 02:23 PM
  #112
Biggy's Avatar
I did the update and that went according to plan. I wanted to try and pair up my iphone 3gs but I cant seem to get it to work. The phone sees uconnect but says it is not paired. When uconnect asks for 4 digit code what numbers are we supposed to use? I dont have a mic yet but I think I should still be able to pair the phone. Any suggestions would be great.
Old Jul 1, 2009 | 02:29 PM
  #113
movielabs's Avatar
Default try using 0000
I used 0000 it worked well.
Old Jul 1, 2009 | 02:36 PM
  #114
Biggy's Avatar
i used 0000 as well but no go
Old Jul 1, 2009 | 03:07 PM
  #115
movielabs's Avatar
Default try this.
initiate the pairing from the radio, hit menu, system setup, phone pairing, follow the connect sequence on the phone, should rock from there.
Old Jul 1, 2009 | 03:47 PM
  #116
whpony96's Avatar
There is a couple things that Nero will allow you to do that Windows won't. Like a closed session and setting the slowest burn speed. These are two things that will ensure that you do not get a messed up image.
Old Jul 1, 2009 | 04:41 PM
  #117
Biggy's Avatar
with the iphone all I have to do is turn on the bluetooth feature and it does the rest right. It searches for uconnect and sees it but it still says not paired.
Old Jul 1, 2009 | 04:58 PM
  #118
movielabs's Avatar
When it sees it it will display on your phone, select it on the phone, the phone should then complete its bluetooth connection.
Old Jul 1, 2009 | 05:03 PM
  #119
Biggy's Avatar
Ya not to tech savvy here. Just got it to work. Just need a mic now, any idea what the part# is. Thanks for the help.
Old Jul 1, 2009 | 06:09 PM
  #120
JeepDawg's Avatar
82211743AB Google is amazing!
Can find it commonly for 32 to 38 bucks.
