need an easy power wire
Looking to wire in some interior LED lights!
Trying to find an "accessory on" wire! There will be driver and passenger light under dash!
Where can I find either one, in center or two seperate wires?
PLEASR HELP!
PLEASR HELP!
Left side cigarette lighter is only on when the ignition is on. Pop off the lower cover, remove the center stack face and you have access.
http://youtu.be/eYIjFTQOv_I
I ran power wire hidden up the A pillar,under the roll bar pads, right behind the dome light. Hooked up the grounds to factory ground points on the left side of driver well, right side of passenger well. Used Max Bright super white led strips, 12 leds per strip. You can also tap into the dome light wire under your center console.
I tied my footwell lights into the wire going to the dome light. I tapped it next to the passenger seat. There's a plastic wire way along the floor. The dome light wire is yellow with a white stripe.
