need help with headlights
Does anyone know how easy it is to fix your headlight angle. mine are pointing in peoples eyes apparently and they keep flashing their brights at me and its getting very annoying.
i have a four inch procomp lift and 35 inch tires
yes remove the plastic grill by removing the clips on top and pulling out the bottom.
you will then have a wide open view of the headlight mounting and adjustment hardware.
play with the adjustment screws and set to your desired angle.
No need to remove the grill, just a long Torx into the little hole access slots on the outsides of the lights. T-15 I think? Clockwise raises, counter-clockwise lowers the light beams. (or vise-versa)
Search on 'headlights' and you'll see many threads on this, with advice on how to adjust for proper height.
i will get on that tomorrow
