New Foglights
Old Dec 26, 2021 | 12:28 PM
Bohead's Avatar
Default New Foglights
Hopefully an easy question for people who know more about wiring than me. Got a new set of fog lights for Christmas. LED with three wires, black red yellow. Previous owner set up two wire plug and play. Easiest way to a
ttach these wires?
Old Dec 26, 2021 | 12:46 PM
Jay2013jk's Avatar
Veteran: National Guard
Community Favorite
Welcome to JKF... Usually Black is Ground.. Red usually HOT.. If you have a Probe test light check the White for 12 v and the Black to ground.. Were there any wiring instructions with the new LEDs? It is clear that you will be splicing together wires. You could try to connect the Red to battery positive and black to ground see if that turns the light on. Will be interesting as to what is the Yellow Function ..
Old Dec 26, 2021 | 01:56 PM
Bohead51's Avatar
No instructions unfortunately.
The yellow wire is what prompted the question. I have no clue what to do with it if I "splice"
Old Dec 26, 2021 | 02:24 PM
Jeff Pillsworth's Avatar
Do the fog lights have a halo ring? I would bench test them with 12 V. Black is certainly ground but you need to figure out what the Red and Yellow do.
Old Dec 26, 2021 | 02:31 PM
Bohead51's Avatar
LED, but no halo
Old Dec 26, 2021 | 02:56 PM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
and do they create enough load on the system to not throw a code. Where were they manufactured if they are new?
Old Dec 26, 2021 | 03:04 PM
Bohead51's Avatar
Just hooked to 12v. Yellow turns on "X" shaped light in center of LEDs.
Haven't hooked them to Jeep yet, so unsure of "code".
Purchased as gift off Amazon, so unsure of manufacturer/origin
Old Dec 26, 2021 | 03:05 PM
Bohead51's Avatar
It appears previous owner used wires from stock bumper fogs
Old Dec 28, 2021 | 07:10 AM
Creepy Neville's Avatar
5 Year Member
Yep - I would follow Sixty4X4's logic -
Somewhere on the lights (or box \ packing tape, etc) there is a name, number, or some other distinguishing mark that can be tracked down.
Did these lights come as 'stand alone' kit (lights + switch) ?
Off the top of my head, I would guess that:
1. Red - Hot
2. Black - Ground
3. Yellow - Switch to turn them on/off
Neville
Old Feb 14, 2022 | 09:26 AM
RwH's Avatar
RwH
Veteran: Navy
Not sure if you found your answer to the purpose of the yellow wire yet, but it's possibly for DRL(Daytime Running Lights) function. My aftermarket lights came with a yellow wire that i just left disconnected.
