JK Electrical, Lighting & Sound SystemsBulletin board forum regarding topics such as stereo head units, CD players, MP3 players, speaker systems, amplifiers, hardmounted GPS devices, computers, headlight upgrades, fog lights, off-road lights, general wiring and anti-theft devices.
Hopefully an easy question for people who know more about wiring than me. Got a new set of fog lights for Christmas. LED with three wires, black red yellow. Previous owner set up two wire plug and play. Easiest way to a
ttach these wires?
Welcome to JKF... Usually Black is Ground.. Red usually HOT.. If you have a Probe test light check the White for 12 v and the Black to ground.. Were there any wiring instructions with the new LEDs? It is clear that you will be splicing together wires. You could try to connect the Red to battery positive and black to ground see if that turns the light on. Will be interesting as to what is the Yellow Function ..
Do the fog lights have a halo ring? I would bench test them with 12 V. Black is certainly ground but you need to figure out what the Red and Yellow do.
Just hooked to 12v. Yellow turns on "X" shaped light in center of LEDs.
Haven't hooked them to Jeep yet, so unsure of "code".
Purchased as gift off Amazon, so unsure of manufacturer/origin
Not sure if you found your answer to the purpose of the yellow wire yet, but it's possibly for DRL(Daytime Running Lights) function. My aftermarket lights came with a yellow wire that i just left disconnected.
