Newcomdigi 52" 300watt LED Light Bar
#852
eBay seller led_sky: led_sky on eBay
Sometimes has 52" bars for $179.95 via bid otherwise they sale for about $202.95 buy it now. A lot of times it doesn't show up with the regular search and I just stumbled across one recently and was the only bidder so got it at $179.95 and had it before the weekend. I've been using these less expensive knock off lights for quiet awhile now to include a 12" and some 2x2s on the a-pillar and I've had great luck with them.
That RSE bar looks great. I just bought a scracth n dent Rough Country mount that I am going to cut down and re-weld so it'll be closer to the cab otherwise I would be all over that. Excellent price as well.
I noticed someone asked about 50" and 52" and knowing the size, usually if it is advertised at 288w it is 50" and 52" is 300w...atleast with eBay sellers.
#853
FINALLY!! HMF Brackets plastidiped, relay harness made up and wired in , light bar installed.
Just did a road test down the highway. No whistle, slight droning sound from 45-60+mph.
Nothing terrible, cause I can still hear my BFG KM2s.
The light bar just make it seem like a windy day out, with the buffering sound.
Overall.... Very pleased and have under $400 in it
#854
If any of you know of a single row lightbar for the same price as the one we all have please tell me, im thinkin thats what I want instead, hurd they don't make buffering noise or whistle
#856
50" inch 300W 100 LED Alloy Spot Flood Combo Work Light Bar 12V 24V Waterproof | eBay
cool found it, still trying to decide if it is worth it or not... I already have a custom relay power distro box wired for it and the interior switches.
#857
300W 50" LED Alloy Spot Flood Combo LED Work Light Bar 12 24V 4X4WD SUV Car Jeep | eBay Is this the same light bar??? I want the 50" not 52" I will also be using RSE Brackets, they sent me install photos and the bar is damn close to flush with the roof, they are also US made. 50" Light Bar Bracket « Rock-Slide Engineering Rock-Slide Engineering
And like the other guy said, the 300 watt is typically a 52" so I think the ad is just wrong.
#858
#859
Its 24 10watt Cree LED's. they are about the same size so same problems. I have door trim on all the fins, and I hot glued bike brake cable in each space between lexan bolts. No whisle, only some droning/buffeting. Those small SR's are made by Rigid...they are not nearly as bright and still cost 2 arms, 1 leg and 10 toes.
Patriot SR 52
#860
I have a 52 inch SR bought from Texas Liberty LED. More than pleased with it. Its 24 10watt Cree LED's. they are about the same size so same problems. I have door trim on all the fins, and I hot glued bike brake cable in each space between lexan bolts. No whisle, only some droning/buffeting. Those small SR's are made by Rigid...they are not nearly as bright and still cost 2 arms, 1 leg and 10 toes. Patriot SR 52
