OEM Fogs
I think we all agree that the OEM fogs are not great and the headlamps leave much to be desired. High beams are useless. After installing Hella driving lights and wiring them to turn on when I turn on the fogs, I was toying with the idea to be able to turn on the Hellas alone OR when I turn on the fogs. But as usual I'm maybe making the lighting thing too complicated. My question for any stock light users is;
Do you find the OEM fogs useful at all?
Do you use them?
When? Rain? Snow? Fog?
Do your high beams provide the right light?
Are you low beams satisfactory?
I know Daniel Stern and at least one other aux light kit maker are out there or soon will be, but frankly I don't want to spend another 2,3 or 4 hundred dollars to add the correct lighting to my unlifted daily driver. Merry Christmas
Do you use them?
I agree the stock headlamps are not great - because of this I always turn on the fogs when I turn on my headlamps. It seems to be th only way I am able to see much. I've been toying with the idea of getting some SilverStars to try and get a little upgrade for a little cash.
Interested to see what others are doing.
I put in Silverstars on my 09 and they helped a bit, eventually i would like to go HID but currently don't want to spend the money on the conversion. Also Pep Boys is running a $10 mail in rebate on them lowering the price for 2 to $30.
Do you find the OEM fogs useful at all? Yes Very
Do you use them? All the time
When? Rain? Snow? Fog? Both and night driving, basicly whenever the low beams are on
Do your high beams provide the right light? There not that great
Are you low beams satisfactory? There alright
I was up on a mountain and if it wernt for the fogs i wouldnt have gotten down. The fog was so thick you couldnt see five feet infrony of you. all the lowbeams did was glare. We ended up driving 16 miles down the mountain with just fogs.
Do you use them?
Do you use them?
Regarding your questions though, I use the fog lights during bad weather only and they work well for me.
Honestly, once my OEM headlights were properly aimed, they work great. Before they were aimed they were very weak/useless as you say and aimed too high which made me get flashed a lot.
I upgraded to Phillips, whatever their high output lamps are. They are quite a bit better than stock bulbs but In my opinion and evidently others, it's the headlamp assenbly that is at fault, not just the lamps. Be careful with just HID in the stock lamp housing, the word on the forum is that you'll get terrible glare and no real improvement. Thanks for the comments. I think I'll leave my Hellas wired the way they are...on with fogs, off with high beam and when fogs off.
I have been kicking around the idea of going with a Daniel Stern solution. Just haven't pulled the trigger on that yet.
