OEM Intergration module for radio
I have a X model with the standard radio. I want to add an external amp and upgrade the existing speakers and add a subwoofer. The wiring harness is not yet available that would allow me to replace the HU. Wouldn't something like an OEM Intergration module allow me to connect between the radio and external amp? See www.audiocontrol.com, OEM Intergration. Something like the LC6i. This way, I could keep the stock HU and still improve the overall sound.
Will that work?
Will that work?
Will that work?
Will that work?
if you're that deadset on keeping the HU, just contact your local dealer and have them upgrade you to the infinity system...because if you're happy with the stock HU, you should be happy with the infinity system.
Thanks for the reply. I'm not deadset on keeping the HU. In fact, I had planned to replace it, but the wiring harness is not yet available. I don't want to cut/splice the factory wiriing, so I thought this oem intergration module might work.
Maybe I should wait on the harness.
I guess everyone has an opinion...
and mine is... yes, you can keep the OEM stereo and use an interface that can sound as good or better than an aftermarket 'hu'. I will be using the JL Audio Cleansweep. Read reviews from trusted audio professionals about this product and others like it before you make 'your decision'.
my 2 cents.
my 2 cents.
Stereo integration OEM
To integrate an AMP with your OEM stereo, you'll need either an amp with "Line Level Inputs" and you'll just run your HU right into the amp, OR you need to get a "Line Level Converter". That has 2 RCA outputs that will run front and rear speakers to an amp that doesn't have line level inputs. Crutchfield has them, made by Scosche (run you about 30 bucks)
