Offroad lights stopped working. Please help!
Old Feb 28, 2012 | 05:39 PM
lucasheasley's Avatar
Default Offroad lights stopped working. Please help!
I have two KC HiLites and two Hella 500FF lights hooked up on one switch, they worked fine for a few minutes, then shut off. I can't figure out how to get them to work again. Anyone know whats wrong? Thanks!
Old Feb 28, 2012 | 06:37 PM
Rich6700's Avatar
Fuse blown, did you use a relay? Could be that.
Old Feb 28, 2012 | 06:52 PM
Orangeav's Avatar
Ditto. Check the fuse.
Old Feb 28, 2012 | 08:20 PM
Got it fixed, and they're working just fine! Thanks.
Old Feb 28, 2012 | 08:54 PM
dogsonparade's Avatar
What did you determine as the cause?
Old Feb 28, 2012 | 08:55 PM
sclan's Avatar
$5 says it was a bad ground.
Old Feb 29, 2012 | 12:24 PM
Sure you wanna make that bet? ha, it was blown fuses. i had four lights off of one wire.
Old Feb 29, 2012 | 12:56 PM
Orangeav's Avatar
Lol! Been there, done that! Really freaks you out at first huh!?! Glad you got it sorted out!
Old Feb 29, 2012 | 01:03 PM
JK-Ford's Avatar
Don't tell me that you put in a bigger fuse!
Old Feb 29, 2012 | 02:59 PM
The general rule is two lights to a harness. Bad ground is one of the primary causes though.
