Plate light wire for relocation
Old Aug 16, 2013 | 11:08 AM
4W-Jive's Avatar
Default Plate light wire for relocation
For those of you who have relocated your plate to your spare tire...
Easy enough to figure out the brake light wiring, but where are you getting the wire lead for a plate light?
Old Aug 17, 2013 | 06:57 PM
4W-Jive's Avatar
Bump
Ten.
Old Aug 18, 2013 | 04:23 PM
scottz's Avatar
I tapped mine into the passenger side tail light. I believe it was the black wire and the white/purple wire.
Old Aug 18, 2013 | 04:28 PM
4W-Jive's Avatar
With a T connector or peeling the insulation and wrapping a wire around it? I take it no flicker or anything weird? Aftermarket brake light or stock?
Old Aug 18, 2013 | 04:39 PM
karls's Avatar
Either will work fine as long as your connection is solid. There's not much current running through there so you won't see anything weird.
Sent from my GT-P5113 using Tapatalk 4
Old Aug 18, 2013 | 04:41 PM
4W-Jive's Avatar
Cool. I've never had much faith in the T connectors, which method would you say is better? And can anyone confirm the tail light wire color on 2012?
Appreciate the help.
Old Aug 18, 2013 | 05:06 PM
karls's Avatar
Scotch locks, I believe they're called, are usually decent. If you're really paranoid then go on ahead and solder the connections. It's the best way to connect them but other methods will work too.
Old Aug 18, 2013 | 05:10 PM
4W-Jive's Avatar
Thanks Karls. Is that something I should look online for or will a store carry those?
Old Aug 18, 2013 | 05:15 PM
boopiejones's Avatar
i just ran it straight from the stock license plate wiring harness using some old speaker wire, ziptied to the frame running underneath the tailgate and then up the tire carrier.
i also used the stock license plate mount, but hacked it up so it sits flush on the tire carrier.
not the best picture, but...
Old Aug 18, 2013 | 06:03 PM
karls's Avatar
There's no reason Wal-Mart or any local auto shop shouldn't have them, worst comes to worst- radio shack has them.
