Plate light wire for relocation
For those of you who have relocated your plate to your spare tire...
Easy enough to figure out the brake light wiring, but where are you getting the wire lead for a plate light?
Scotch locks, I believe they're called, are usually decent. If you're really paranoid then go on ahead and solder the connections. It's the best way to connect them but other methods will work too.
Sent from my GT-P5113 using Tapatalk 4
i just ran it straight from the stock license plate wiring harness using some old speaker wire, ziptied to the frame running underneath the tailgate and then up the tire carrier.
i also used the stock license plate mount, but hacked it up so it sits flush on the tire carrier.
not the best picture, but...
