Problem wiring up KC lights.
Old Jun 18, 2012 | 06:04 PM
Greep's Avatar
This ought to help light up the trails when we go to Colorado this July. It gets really dark out there... Especially if you are in a new area!
Old Jul 5, 2012 | 07:31 AM
osubauer's Avatar
Did you use Daylighters or Slimlines? I was wondering if the Daylighters would hit the windshield as they are so much bigger.
Old Jul 5, 2012 | 08:20 AM
JK-Ford's Avatar
Daylighters work just fine.
Old Jul 5, 2012 | 08:44 AM
hypeiv's Avatar
I had the same problem when I installed mine... relay didn't have a good enough ground. There a bunch of bolts into metal under the hood that arn't actually grounded
Old Jul 5, 2012 | 09:43 AM
maverick17's Avatar
One way to test for a good ground is to use a VOM and check for continuity between the bolt (you want to use for a ground point) and the Negative terminal of the battery.
Old Jul 5, 2012 | 11:38 AM
JK-Ford's Avatar
An even better way to make sure that you have an "assured ground" is to run a ground wire back to the battery.
Old Jul 5, 2012 | 08:08 PM
MrJCM1984's Avatar
I got these and did the install myself. Took a while for the ones on my bumper, but once I got it figured out it worked great. Drilled 2 holes just left of the steering column...well the gf did as you can tell. Works great though.
ID:	337876   Click image for larger version
ID:	337880   Click image for larger version
