Psx24w led bulbs
I have similar ones in mine. They are super bright and work well. You have to watch because sometimes the fitment isn't perfect. The left fog light won't snap in all the way on one side. Tried it with both bulbs. Mine came from eBay and were about $25. They match trucklites perfectly. But my bulbs have a little bluish hue to them. The the lens kind of makes them more on the spotlight side rather than the floodlight side. You can see the cutoff on the ground. Hope that helps. Sent from my iPhone using JK-Forum
I have a similar set I got off Amazon.
They are as bright as stock, but I had to carefully sand down the o-ring to get them to lock into the housing. Also, there are certain tabs you will have to grind off from the bulb base. Compare them to the stock bulbs to know which ones.
