Question on adding an amp.
Old Jun 9, 2011 | 09:26 AM
outlikealight's Avatar
Default Question on adding an amp.
I went to a local shop and looked at speakers and amps. We were talking price and the sales guy added at the end that with the Jeep they have to bypass the factory amp and this was a $100 additional charge on installation. Sounded a little off but to be honest I don't know a thing about stereo installation.
Any help would be appreciated.
Chris
Old Jun 9, 2011 | 09:38 AM
scotty6336's Avatar
Yeah that sounds about right. They most likely have to use a harness adapter to bypass the amp, and this will likely be the same anywhere you go to...unless they hook it up wrong
Old Jun 9, 2011 | 09:49 AM
EAZY-E's Avatar
Only if you have the infinty system. If not they would most likely do a line out converter (if keeping factory radio, if not this does not apply). If not everything needed is usually always packaged on the new headunit.
Old Jun 9, 2011 | 09:51 AM
I do have the Infinity system and a new head unit already installed. Thanks for the quick replies. I appreciate it.
Old Jun 12, 2011 | 02:37 PM
bc4850's Avatar
I had an amp installed in my jeep with a line out converter, and I have the infinity system. I had no problems with mine.
Old Jun 12, 2011 | 05:48 PM
NH-JK's Avatar
If you have a new head unit, you can run rca's to your amp and then add subs to the rear and not have to touch the other speakers....or amp. If you want to add a 4 channel amp and power all your speakers fronts and sound bar, then that's different. What are you looking to add?
Old Jun 12, 2011 | 09:11 PM
I have an amp for my sub. I want to add a four channel amp and 4 new speakers. Thanks for the input.
Old Jun 12, 2011 | 09:21 PM
apeezee's Avatar
If u have an aftermarket head unit that is not a mygig, u should have all the needed plugs on the back of the head unit and you do not need to run a LOC ( line out converter) to bypass the amp. Aftermarket head units have RCA outputs that are made for this exact thing. U just run the RCAs to the amp and this carries your audio signal. I had to add a LOC when I added my amp because i have a factory head unit. Which head unit do you have?
Old Jun 13, 2011 | 02:21 AM
Pioneer AVIC Z120BT
Old Jun 13, 2011 | 05:50 AM
apeezee's Avatar
Yeah u have three RCA outputs. U do do NOT have to "bypass the infinity amp". don't let them charge u for that. Because u have that head unit it should be a standard install for them.
