Question for those with aftermarket headunit and SiriusXM Radio....
Old Feb 12, 2013 | 09:58 AM
07UnlimitedMD's Avatar
Default Question for those with aftermarket headunit and SiriusXM Radio....
Where did you put the antenna to get the best reception?
Old Feb 12, 2013 | 10:03 AM
JK-Ford's Avatar
Same place as the OE antenna. On top of the speaker bar over the passanger seat.
GreenJK07's Avatar
Highest possible point on the vehicle. I used to have mine on the front cowl by the wipers. I had signal loss very frequently and moved the antenna to a roll bar mount when I had it(I don't run a top on my jeep). No loss of reception when it was on the roll cage. May want to stick it on the roof of your hardtop if you don't have a soft top.
Old Feb 12, 2013 | 10:06 AM
JK-Ford's Avatar
Thought about doing that with my NAV antenna. But I decided not to. I thought that I may want to take my top off again next spring.
Old Feb 12, 2013 | 05:37 PM
TJM12's Avatar
I mounted my Sirius antenna on my dash as close to the windshield as possible. Between the vents right in the middle of the dash there is a little partition that I stuck it too, works great. Only drops out underneath overpasses or when there is a blockage to the sky.
Old Feb 13, 2013 | 06:09 AM
Marmot mb's Avatar
I mounted mine some time ago under the padding on top of the sound bar. I never loose signal unless going under a bridge or in high tree area's along the road.
The hard top or soft top on or off doesn't seem to make any difference in signal quality.
