Question for those with aftermarket headunit and SiriusXM Radio....
Highest possible point on the vehicle. I used to have mine on the front cowl by the wipers. I had signal loss very frequently and moved the antenna to a roll bar mount when I had it(I don't run a top on my jeep). No loss of reception when it was on the roll cage. May want to stick it on the roof of your hardtop if you don't have a soft top.
I mounted my Sirius antenna on my dash as close to the windshield as possible. Between the vents right in the middle of the dash there is a little partition that I stuck it too, works great. Only drops out underneath overpasses or when there is a blockage to the sky.
I mounted mine some time ago under the padding on top of the sound bar. I never loose signal unless going under a bridge or in high tree area's along the road.
The hard top or soft top on or off doesn't seem to make any difference in signal quality.
