Questions about adding an aftermarket sub to Infinity system
What about the wiring? Where did you take your signal from? Did you use any sort of LOC or does the amp take a high level input? What about the sub rolloff?
Boy I'm full of questions!
No we installed a Kenwood 5120 deck, sorry should have mentioned that, when we bought the jeep, we looked at two identical jeeps except one had mygig in it and it was $2500.00 higher. So we bought the cheaper one and then went to the audio shop and had the kenwood installed for 999.00 with Garmin Nav.
If you don't already have the stock sub, is the wiring still there, hidden somewhere, or would you need to use LOC and tap into the soundbar? Is the power already there as well?
I'm hoping there is a plug already wired in the back of the jeep with audio and power.
I also like the stock look for going topless
I understand that, I would find a good audio shop and get them to give you a price on what you want to do and list of what you need and then do it yourself if thier to high, I do that all the time, the installer I used wanted like $250.00 just to make the subbox so I did it myself for like $75 after finding how much airspace the box needed. When we go topless we take the box out.
For my sub(s) I plan on eventually doing a stealth install under the back seats that should keep everything safely out of sight
