rear speaker help please
in my 2007 jk x the speakers that are attached to the roll bar stink..... is this due to the radio output or the speakers themselfs. and what size are they to change them out. thank you
both.
stock paper cone speakers dont hit very hard.
stock radio is made to limit the sound to soundbar due to the speakers being close to the heads of passengers.
6.5s will fit.
https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/fix-soundbar-speakers-4017/
6.5s will fit.
i am in the process of gathering my system parts together.
i have the speakers from my previous car, an amp to power them, bought a new headunit from crutchfield, got an amp for the sub and now im just waiting to pick up a sub, some plug and play speaker adapters from crutchfield and some polyfill. oh and the wiring for the amps.
I changed the rears prior to changing out the head-unit, and the sound was better, but not the volume.
6.5 inch speakers will fit. However, the stock mounting brackets use 3 mounting holes, after-market speakers normally use 4.
Here is a write-up and some photos: https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/my-soundbar-speaker-replacement-non-infinity-24559/
I put JL Audios 6.5" all the way around (components in the front position)...and it sounds superb. People are right though...change your head unit for increased volume and punch. Throwing in a dedicated amp to power JUST the speakers is also a great addition as well.
Russ D.
Russ D.
Russ D.
Russ D.
ill be using my xr650 cxi and csi with a 300/4.
