Recycling factory foglight wiring?
Hey guys, Im going to be adding a PureJeep bare bonez front bumper in a few weeks and it doesnt accomodate factory foglamps. I was wondering if I could use the wiring for the foglamps to run a set of aftermarket lights on the bumper?
I was told by the guys at 4wd Parts (Santa Ana) that you cannot use the factory wiring for aftermarket lights. They say the wiring is too small. I have no reason not to believe them, but I did have them tuck the wires up under for future use.
Eternal ***erator
This comes up a lot. There are many older threads on this. It is a yes and no answer, yes you can, if you use small wattage aftermarket lights, if you use something like KC's then no, you'll exceed the draw of the factory fogs & the computer will read it as a fault and shut them down.
I am running 100W KC's and i use the factory wiring to trigger the relay that came with them, not to power them. The relay grabs juice directly from the battery. (That way there is negligible draw on the factory wiring, far less than the original fogs had)
The way i wired them i still use my factory stalk switch to turn them on/off.
this is how my aftermarket fogs are wired into the factory wiring:
Wow, some of you guys have wiring knowledge that baffles me. Maybe its time for me to get a book or two and read them. I can ride, rope, and weld, but when you get into relays and fuses and whatnot im lost.
Ill look at your diagram and see if i can make some sense of it happy. Thanks!
Edit: Just looked at the diagram and it looks like until I get that book I'm still lost. I wonder if anyone around here wires proffesionally like that...
http://www.mp3car.com/vbulletin/faq-...w-wire-up.html
http://www.reuk.co.uk/Automotive-Relays.htm
Hopefully this helps. If not, ask again. There's a wealth of free help on this forum. No need to buy a book.
