RER Ipod integration on '09
Ok, manual says it works, folks on Dodge forum say it works, but no one knows where to plug the cable in. I purchased the cable from the dealer. I need to know where to locate the factory installed Uconnect box on an 09 Wrangler Unlimited. It is not under the glove box, I've had that all apart. I've searched on here for days to no avail. Thanks in advance.
<--------- First time poster JEEP wave.
It should just plug into the back of the mygig.
Take the dash panel off, pull the mygig out, and it should just go inline in the back of the radio. Done.
If you bought the iPod integration cable to go with the uconnect boxes for the other radios, it's the wrong thing.
And howdy from the other side of 540
If you're not sure about it, and ever make it to RTP or N Raleigh, let me know and I can take a look and let you know if you have the right cable.
The plug that "matches" the integration plug is for the Uconnect microphone on the back of the Mygig correct? Too many options on these radios and not enough available info yet.
Item # 82210787AB - For Jeeps with factory UConnect.
I guess it won't currently work with the RER huh?
What is the correct cable number?
