Rugged Ridge A Pillar Switch Pod
Old 03-13-2013, 07:27 AM
  #81
El Jeepo's Avatar
Yes, my switch configuration has 5 leads. Two of them were connected to ground (upper and lower led grounds), 1 to the orange/ gray wire (lower led, the green led with my switch letters), and the other two went to the lights (I have KCs, so 1 went to the relay- green wire I think- and the other to the white KC wire- i Think it was the 12V fused wire).
Old 03-13-2013, 10:18 AM
  #82
ngeiman2002's Avatar
Do anybody seem to have a problem of wind whistling when the window is down since they installed this pod
Old 03-13-2013, 03:36 PM
  #83
jwilson2598's Avatar
Ok, that's what I was figuring. Thanks for your help with this. It is very much appreciated.
Old 03-13-2013, 08:03 PM
  #84
Grand Umpah's Avatar
Installed my RR A-pillar switch panel today, in my '12 JKUR.
Would agree that the fit is not what I would have hoped; took a lot of pushing and prodding to get the right-side edge lined up to the windshield, only to have a gap on the edge near the door. WIth the door closed, you can't see it, but damn, I know it's there.
But the OTRATTW switches are perfect, and I even managed to wire them correctly, so I'm good to go.
Old 03-15-2013, 04:35 AM
  #85
JKU2007's Avatar
Here's mine.
Old 04-22-2013, 05:22 PM
  #86
Wolf_425's Avatar
Originally Posted by JKU2007
Here's mine.
Those are badass!
Old 04-29-2013, 06:36 AM
  #87
Phantasm's Avatar
Added a new switch to mine on top of the other 2, since it is above the cutouts, the top switch required that I take out some of the plastic support in the back. Nothing that is going to cause a problem maybe 1 sq in or so near the plastic post index piece that doesn't clamp to anything just goes in to a hole. These switches only require a 7/16th hole to mount making it easier to install. They are rated 30A but are only driving relays in my setup.
Quick Reply: Rugged Ridge A Pillar Switch Pod
